Lian Li
Arctic
UNI FAN SL-INF 120
P12 PWM
210 g
139 g
200 U/min
2100 U/min
1800 U/min
3.0 W
61.3 CFM
56.3 CFM
104.1 m³/h
2.66 mmH2O
2.20 mmH2O
29.0 dBA
Silber
3.5 V
3.0 V
913 U/min
207 U/min
742 U/min
547 U/min
290 U/min
298 U/min
2134 U/min
1748 U/min
886 U/min
30.0 CFM
+12.0 %
33.5 CFM
23.8 CFM
+2.6 %
23.2 CFM
21.5 CFM
+6.8 %
23.0 CFM
22.3 CFM
+3.6 %
21.5 CFM
50.9 m³/h
+12.0 %
57.0 m³/h
40.5 m³/h
+2.5 %
39.5 m³/h
36.6 m³/h
+6.8 %
39.1 m³/h
37.9 m³/h
+3.6 %
36.6 m³/h
+42.0 %
+16.4 %
0.51 mmH2O
+2.0 %
0.51 mmH2O
+19.6 %
+39.3 %
+16.0 %
+0.0 %
+20.0 %
32.6
-11.2 %
36.7
33.5
-3.5 %
34.7
32.6
-6.1 %
34.7
33.5
-2.6 %
34.4
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
