Lian Li
Corsair
UNI FAN SL-INF 120
ML 120 RGB Elite
210 g
186 g
450 U/min
2100 U/min
3.0 W
1.6 W
61.3 CFM
58.1 CFM
104.1 m³/h
98.7 m³/h
2.66 mmH2O
2.90 mmH2O
29.0 dBA
30.4 dBA
3.5 V
3.0 V
913 U/min
510 U/min
742 U/min
450 U/min
290 U/min
169 U/min
298 U/min
84 U/min
2134 U/min
1993 U/min
886 U/min
30.0 CFM
+17.7 %
35.2 CFM
23.8 CFM
+1.5 %
24.2 CFM
21.5 CFM
+10.1 %
23.7 CFM
22.3 CFM
+4.7 %
21.3 CFM
50.9 m³/h
+17.7 %
59.9 m³/h
40.5 m³/h
+1.5 %
41.1 m³/h
36.6 m³/h
+10.1 %
40.3 m³/h
37.9 m³/h
+4.7 %
36.2 m³/h
0.71
0.71
+16.4 %
0.51 mmH2O
+19.6 %
0.51 mmH2O
+39.2 %
+0.5 %
+16.0 %
+20.0 %
+40.0 %
32.6
-12.6 %
28.5
33.5
-11.9 %
29.5
32.6
-12.6 %
28.5
33.5
-17.0 %
27.8
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
  • 169
  • 369
  • 569
  • 769
  • 969
  • 1169
  • 1369
  • 1569
  • 1769
  • 1969
