Lian Li
Corsair
UNI FAN SL-INF 120
QL120 RGB
210 g
163 g
500 U/min
2100 U/min
1500 U/min
3.0 W
61.3 CFM
41.8 CFM
104.1 m³/h
2.66 mmH2O
1.55 mmH2O
29.0 dBA
26.0 dBA
Silber
Halbtransparent
3.5 V
3.0 V
913 U/min
245 U/min
742 U/min
472 U/min
290 U/min
298 U/min
2134 U/min
1600 U/min
886 U/min
30.0 CFM
+7.8 %
27.8 CFM
23.8 CFM
+15.7 %
20.6 CFM
21.5 CFM
+12.3 %
19.2 CFM
22.3 CFM
+29.4 %
17.2 CFM
50.9 m³/h
+7.8 %
47.2 m³/h
40.5 m³/h
+15.7 %
35.0 m³/h
36.6 m³/h
+12.3 %
32.6 m³/h
37.9 m³/h
+29.4 %
29.3 m³/h
+42.3 %
1.01 mmH2O
+42.0 %
0.51 mmH2O
+2.0 %
0.51 mmH2O
+27.5 %
0.40 mmH2O
+43.6 %
+39.3 %
+0.0 %
+25.0 %
32.6
-15.1 %
38.4
33.5
-12.5 %
38.3
32.6
-9.2 %
35.9
33.5
-6.4 %
35.8
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
