Lian Li
Blacknoise
UNI FAN SL-INF 120
NB-eLoop X PWM B12xP ARGB
210 g
120 g
400 U/min
2100 U/min
3.0 W
61.3 CFM
77.9 CFM
104.1 m³/h
132.4 m³/h
2.66 mmH2O
3.02 mmH2O
29.0 dBA
28.4 dBA
Grau
3.5 V
3.4 V
913 U/min
294 U/min
742 U/min
138 U/min
290 U/min
298 U/min
2134 U/min
2002 U/min
886 U/min
30.0 CFM
+35.4 %
40.5 CFM
23.8 CFM
+4.4 %
24.9 CFM
21.5 CFM
+6.8 %
23.0 CFM
22.3 CFM
+6.2 %
21.0 CFM
50.9 m³/h
+35.4 %
68.9 m³/h
40.5 m³/h
+4.4 %
42.3 m³/h
36.6 m³/h
+6.8 %
39.1 m³/h
37.9 m³/h
+6.2 %
35.7 m³/h
+101.4 %
1.43 mmH2O
+14.1 %
0.51 mmH2O
+19.6 %
0.51 mmH2O
+2.0 %
+101.1 %
0.14 hPa
+14.9 %
+20.0 %
+0.0 %
32.6
-5.2 %
34.4
33.5
-8.2 %
36.5
32.6
-9.2 %
35.9
33.5
-7.2 %
36.1
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
