Lian Li
UNI FAN SL-INF 120
Silent Wings 3
210 g
137 g
150 U/min
2100 U/min
1450 U/min
3.0 W
61.3 CFM
50.5 CFM
104.1 m³/h
85.8 m³/h
2.66 mmH2O
1.79 mmH2O
29.0 dBA
16.4 dBA
3.5 V
4.1 V
3.9 V
913 U/min
742 U/min
290 U/min
206 U/min
298 U/min
244 U/min
2134 U/min
1411 U/min
886 U/min
30.0 CFM
+32.9 %
22.5 CFM
23.8 CFM
+19.8 %
19.9 CFM
21.5 CFM
+25.0 %
17.2 CFM
22.3 CFM
+33.0 %
16.8 CFM
50.9 m³/h
+32.9 %
38.3 m³/h
40.5 m³/h
+19.8 %
33.8 m³/h
36.6 m³/h
+24.9 %
29.3 m³/h
37.9 m³/h
+33.0 %
28.5 m³/h
+42.3 %
1.01 mmH2O
0.71
0.71
0.51 mmH2O
+39.2 %
0.51 mmH2O
+2.0 %
+42.3 %
0.0696253
0.0696253
+39.2 %
+2.0 %
32.6
-11.4 %
36.8
33.5
-19.9 %
41.8
32.6
-19.5 %
40.5
33.5
-17.5 %
40.6
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
