Lian Li
Lian Li
UNI FAN SL-INF 120
UNI FAN SL120 ARGB
210 g
232 g
800 U/min
2100 U/min
1900 U/min
3.0 W
61.3 CFM
58.5 CFM
104.1 m³/h
99.5 m³/h
2.66 mmH2O
1.67 mmH2O
29.0 dBA
31.0 dBA
Silber
3.5 V
2.4 V
913 U/min
412 U/min
742 U/min
98 U/min
290 U/min
298 U/min
2134 U/min
1828 U/min
886 U/min
30.0 CFM
+28.9 %
23.2 CFM
23.8 CFM
+34.6 %
17.7 CFM
21.5 CFM
+36.1 %
15.8 CFM
22.3 CFM
+45.8 %
15.3 CFM
50.9 m³/h
+28.9 %
39.5 m³/h
40.5 m³/h
+34.6 %
30.1 m³/h
36.6 m³/h
+36.1 %
26.9 m³/h
37.9 m³/h
+45.8 %
26.0 m³/h
+77.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
0.51 mmH2O
+27.5 %
0.40 mmH2O
0.51 mmH2O
+27.5 %
0.40 mmH2O
+74.1 %
+74.1 %
+25.0 %
+25.0 %
32.6
-16.0 %
38.8
33.5
-8.7 %
36.7
32.6
-9.7 %
36.1
33.5
-3.2 %
34.6
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
