Lian Li
Corsair
UNI FAN SL-INF 120
LL140 RGB
210 g
210 g
600 U/min
2100 U/min
1300 U/min
3.0 W
61.3 CFM
51.5 CFM
104.1 m³/h
87.5 m³/h
2.66 mmH2O
1.52 mmH2O
29.0 dBA
25.0 dBA
Halbtransparent
3.5 V
2.9 V
913 U/min
226 U/min
742 U/min
378 U/min
290 U/min
298 U/min
2134 U/min
1319 U/min
886 U/min
30.0 CFM
+50.3 %
45.0 CFM
23.8 CFM
+19.0 %
28.4 CFM
21.5 CFM
+13.7 %
24.5 CFM
22.3 CFM
+18.5 %
26.4 CFM
50.9 m³/h
+50.3 %
76.5 m³/h
40.5 m³/h
+19.0 %
48.2 m³/h
36.6 m³/h
+13.7 %
41.6 m³/h
37.9 m³/h
+18.5 %
44.9 m³/h
+18.3 %
0.60 mmH2O
+42.0 %
0.51 mmH2O
+2.0 %
0.51 mmH2O
+19.6 %
+16.0 %
+39.3 %
+0.0 %
+20.0 %
32.6
-7.6 %
35.3
33.5
-9.2 %
36.9
32.6
-4.1 %
34
33.5
-3.7 %
34.8
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
