Lian Li
Noctua
UNI FAN SL-INF 120
NF-A14 FLX
210 g
210 g
900 U/min
2100 U/min
1200 U/min
3.0 W
61.3 CFM
68.0 CFM
104.1 m³/h
115.5 m³/h
2.66 mmH2O
1.51 mmH2O
29.0 dBA
19.2 dBA
Beige
Braun
Braun
3.5 V
4.6 V
4.2 V
913 U/min
381 U/min
742 U/min
469 U/min
290 U/min
298 U/min
2134 U/min
1199 U/min
886 U/min
30.0 CFM
+78.6 %
53.5 CFM
23.8 CFM
+38.3 %
33.0 CFM
21.5 CFM
+47.0 %
31.7 CFM
22.3 CFM
+35.1 %
30.1 CFM
50.9 m³/h
+78.6 %
90.9 m³/h
40.5 m³/h
+38.3 %
56.0 m³/h
36.6 m³/h
+47.0 %
53.8 m³/h
37.9 m³/h
+35.1 %
51.2 m³/h
+28.2 %
0.91 mmH2O
+28.2 %
0.91 mmH2O
0.51 mmH2O
+2.0 %
0.51 mmH2O
+70.0 %
0.30 mmH2O
+29.3 %
0.09 hPa
+29.3 %
0.09 hPa
+0.0 %
+66.7 %
0.03 hPa
32.6
-4.7 %
34.2
33.5
-21.4 %
42.6
32.6
-20.1 %
40.8
33.5
-16.0 %
39.9
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
