Lian Li
Thermaltake
UNI FAN SL-INF 120
210 g
212 g
500 U/min
2100 U/min
3.0 W
61.3 CFM
58.4 CFM
104.1 m³/h
99.1 m³/h
2.66 mmH2O
2.41 mmH2O
29.0 dBA
22.3 dBA
Grau
3.5 V
913 U/min
391 U/min
742 U/min
413 U/min
290 U/min
298 U/min
2134 U/min
1950 U/min
886 U/min
30.0 CFM
+10.8 %
33.2 CFM
23.8 CFM
+5.7 %
25.2 CFM
21.5 CFM
+13.6 %
24.5 CFM
22.3 CFM
+7.1 %
20.8 CFM
50.9 m³/h
+10.8 %
56.4 m³/h
40.5 m³/h
+5.7 %
42.8 m³/h
36.6 m³/h
+13.6 %
41.6 m³/h
37.9 m³/h
+7.1 %
35.4 m³/h
+159.2 %
1.84 mmH2O
+14.1 %
0.51 mmH2O
+2.0 %
0.51 mmH2O
+27.5 %
0.40 mmH2O
+159.2 %
0.18 hPa
+14.1 %
+2.0 %
+27.5 %
32.6
-12.8 %
37.4
33.5
-8.2 %
36.5
32.6
-9.4 %
36
33.5
-7.5 %
36.2
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
