Arctic
Pure Wings 2
P12 PWM
93 g
139 g
300 U/min
200 U/min
1500 U/min
1800 U/min
51.4 CFM
56.3 CFM
1.25 mmH2O
2.20 mmH2O
20.2 dBA
Silber
3.0 V
202 U/min
207 U/min
324 U/min
547 U/min
1488 U/min
1748 U/min
31.5 CFM
+6.5 %
33.5 CFM
22.1 CFM
+5.3 %
23.2 CFM
21.3 CFM
+8.0 %
23.0 CFM
20.8 CFM
+3.4 %
21.5 CFM
53.5 m³/h
+6.5 %
57.0 m³/h
37.5 m³/h
+5.3 %
39.5 m³/h
36.2 m³/h
+8.0 %
39.1 m³/h
35.4 m³/h
+3.4 %
36.6 m³/h
+42.0 %
+16.4 %
0.5
0.5
+22.0 %
+40.0 %
+16.7 %
0.05
0.05
+20.0 %
38.2
-3.9 %
36.7
36.7
-5.4 %
34.7
36
-3.6 %
34.7
36.2
-5.0 %
34.4
