Cooler Master
Pure Wings 2
Sickleflow 140 ARGB
93 g
195 g
300 U/min
650 U/min
1500 U/min
1400 U/min
51.4 CFM
67.0 CFM
113.8 m³/h
1.25 mmH2O
2.25 mmH2O
20.2 dBA
27.0 dBA
Halbtransparent
5.5 V
2.9 V
202 U/min
599 U/min
324 U/min
495 U/min
1488 U/min
1374 U/min
31.5 CFM
+44.0 %
45.3 CFM
22.1 CFM
+27.2 %
28.1 CFM
21.3 CFM
+22.4 %
26.1 CFM
20.8 CFM
+29.7 %
27.0 CFM
53.5 m³/h
+43.9 %
77.0 m³/h
37.5 m³/h
+27.2 %
47.7 m³/h
36.2 m³/h
+22.4 %
44.3 m³/h
35.4 m³/h
+29.7 %
45.9 m³/h
+42.0 %
+42.0 %
0.5
0.5
0.5
0.5
+40.0 %
+40.0 %
0.05
0.05
0.05
0.05
38.2
-7.1 %
35.5
36.7
-1.3 %
37.2
36
-8.9 %
32.8
36.2
-7.5 %
33.5
