Noctua
Pure Wings 2
NF-A14 FLX
93 g
210 g
300 U/min
900 U/min
1500 U/min
1200 U/min
51.4 CFM
68.0 CFM
115.5 m³/h
1.25 mmH2O
1.51 mmH2O
20.2 dBA
19.2 dBA
Beige
Braun
Braun
4.6 V
4.2 V
202 U/min
381 U/min
324 U/min
469 U/min
1488 U/min
1199 U/min
31.5 CFM
+70.0 %
53.5 CFM
22.1 CFM
+49.3 %
33.0 CFM
21.3 CFM
+48.7 %
31.7 CFM
20.8 CFM
+44.7 %
30.1 CFM
53.5 m³/h
+69.9 %
90.9 m³/h
37.5 m³/h
+49.3 %
56.0 m³/h
36.2 m³/h
+48.6 %
53.8 m³/h
35.4 m³/h
+44.6 %
51.2 m³/h
+28.2 %
0.91 mmH2O
+28.2 %
0.91 mmH2O
0.5
0.5
+66.7 %
0.30 mmH2O
+28.6 %
0.09 hPa
+28.6 %
0.09 hPa
0.05
0.05
+66.7 %
0.03 hPa
38.2
-10.5 %
34.2
36.7
-13.8 %
42.6
36
-11.8 %
40.8
36.2
-9.3 %
39.9
