Razer
Cooler Master
Kunai Chroma
Masterfan MF120 Halo
182 g
180 g
650 U/min
2200 U/min
1800 U/min
1.9 W
3.4 W
65.0 CFM
47.2 CFM
110.4 m³/h
2.47 mmH2O
35.0 dBA
30.0 dBA
Grau
Halbtransparent
4.5 V
3.3 V
4.4 V
902 U/min
166 U/min
637 U/min
590 U/min
249 U/min
251 U/min
2124 U/min
1792 U/min
660 U/min
29.9 CFM
+20.9 %
24.8 CFM
19.1 CFM
+4.4 %
19.9 CFM
17.3 CFM
+17.0 %
20.2 CFM
5.8 CFM
+199.3 %
17.2 CFM
50.9 m³/h
+20.9 %
42.1 m³/h
32.4 m³/h
+4.3 %
33.8 m³/h
29.4 m³/h
+6.8 %
31.4 m³/h
9.8 m³/h
+199.0 %
29.3 m³/h
+52.5 %
0.40 mmH2O
0.41 mmH2O
+97.6 %
0.41 mmH2O
+2.5 %
0.40 mmH2O
0.20 mmH2O
+100.0 %
0.40 mmH2O
+50.0 %
+100.0 %
0.04
0.04
0.02 hPa
+100.0 %
32.1
-15.1 %
37.8
33.8
-7.1 %
36.4
33.7
-7.7 %
36.5
35.8
-0.6 %
35.6
  • 249
  • 449
  • 649
  • 849
  • 1049
  • 1249
  • 1449
  • 1649
  • 1849
  • 2049
