Sharkoon
Arctic
Silent Storm PWM RGB Fan
P12 PWM PST RGB 0dB
168 g
159 g
400 U/min
1400 U/min
2.6 W
48.8 CFM
121.9 m³/h
82.9 m³/h
1.47 mmH2O
1.85 mmH2O
34.7 dBA
Grau
Halbtransparent
4.0 V
1.9 V
2.9 V
506 U/min
380 U/min
54 U/min
532 U/min
1413 U/min
1985 U/min
440 U/min
41.1 CFM
+27.9 %
32.1 CFM
31.9 CFM
+33.4 %
23.9 CFM
30.7 CFM
+33.2 %
23.0 CFM
33.6 CFM
+52.2 %
22.1 CFM
69.8 m³/h
+27.9 %
54.6 m³/h
54.3 m³/h
+33.4 %
40.7 m³/h
52.1 m³/h
+33.3 %
39.1 m³/h
57.1 m³/h
+52.3 %
37.5 m³/h
0.81
0.81
+16.4 %
+16.4 %
0.51 mmH2O
+19.6 %
0.08
0.08
+16.7 %
+16.7 %
+20.0 %
32.6
-3.6 %
33.8
32.7
-3.4 %
31.6
33.2
-1.5 %
32.7
32.1
32.1
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
