Sharkoon
Blacknoise
Silent Storm PWM RGB Fan
B12x-PS-BL PWM ARGB
168 g
120 g
400 U/min
1400 U/min
1500 U/min
2.6 W
58.1 CFM
121.9 m³/h
98.7 m³/h
1.47 mmH2O
1.80 mmH2O
34.7 dBA
21.2 dBA
3.3 V
1.9 V
506 U/min
386 U/min
54 U/min
570 U/min
1413 U/min
1491 U/min
440 U/min
41.1 CFM
+12.2 %
36.6 CFM
31.9 CFM
+35.7 %
23.5 CFM
30.7 CFM
+28.0 %
23.9 CFM
33.6 CFM
+47.6 %
22.8 CFM
69.8 m³/h
+12.2 %
62.2 m³/h
54.3 m³/h
+35.7 %
40.0 m³/h
52.1 m³/h
+30.9 %
39.8 m³/h
57.1 m³/h
+47.5 %
38.7 m³/h
+38.3 %
1.12 mmH2O
0.71
0.71
+16.4 %
0.51 mmH2O
+39.2 %
+37.5 %
0.11 hPa
0.07
0.07
+16.7 %
+40.0 %
32.6
-15.8 %
38.7
32.7
-13.7 %
37.9
33.2
-15.1 %
39.1
32.1
-13.2 %
37
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
