Sharkoon
Corsair
Silent Storm PWM RGB Fan
QL120 RGB
168 g
163 g
400 U/min
500 U/min
1400 U/min
1500 U/min
2.6 W
41.8 CFM
121.9 m³/h
1.47 mmH2O
1.55 mmH2O
34.7 dBA
26.0 dBA
Silber
Halbtransparent
3.0 V
1.9 V
506 U/min
245 U/min
54 U/min
472 U/min
1413 U/min
1600 U/min
440 U/min
41.1 CFM
+47.9 %
27.8 CFM
31.9 CFM
+55.1 %
20.6 CFM
30.7 CFM
+59.9 %
19.2 CFM
33.6 CFM
+94.9 %
17.2 CFM
69.8 m³/h
+47.9 %
47.2 m³/h
54.3 m³/h
+55.1 %
35.0 m³/h
52.1 m³/h
+59.8 %
32.6 m³/h
57.1 m³/h
+94.9 %
29.3 m³/h
+24.7 %
1.01 mmH2O
+42.0 %
+42.0 %
0.51 mmH2O
+27.5 %
0.40 mmH2O
+25.0 %
+40.0 %
+40.0 %
+25.0 %
32.6
-15.1 %
38.4
32.7
-14.6 %
38.3
33.2
-7.5 %
35.9
32.1
-10.3 %
35.8
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
