Sharkoon
Blacknoise
Silent Storm PWM RGB Fan
NB-eLoop X PWM B12xP ARGB
168 g
120 g
400 U/min
400 U/min
1400 U/min
2.6 W
77.9 CFM
121.9 m³/h
132.4 m³/h
1.47 mmH2O
3.02 mmH2O
34.7 dBA
28.4 dBA
Grau
3.4 V
1.9 V
506 U/min
294 U/min
54 U/min
138 U/min
1413 U/min
2002 U/min
440 U/min
41.1 CFM
+1.3 %
40.5 CFM
31.9 CFM
+28.4 %
24.9 CFM
30.7 CFM
+33.2 %
23.0 CFM
33.6 CFM
+59.9 %
21.0 CFM
69.8 m³/h
+1.3 %
68.9 m³/h
54.3 m³/h
+28.4 %
42.3 m³/h
52.1 m³/h
+33.2 %
39.1 m³/h
57.1 m³/h
+59.9 %
35.7 m³/h
+76.5 %
1.43 mmH2O
+14.1 %
+16.4 %
0.51 mmH2O
+2.0 %
+75.0 %
0.14 hPa
+14.3 %
+16.7 %
0.05
0.05
32.6
-5.2 %
34.4
32.7
-10.4 %
36.5
33.2
-7.5 %
35.9
32.1
-11.1 %
36.1
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
