Sharkoon
Corsair
Silent Storm PWM RGB Fan
LL140 RGB
168 g
210 g
400 U/min
600 U/min
1400 U/min
1300 U/min
2.6 W
51.5 CFM
121.9 m³/h
87.5 m³/h
1.47 mmH2O
1.52 mmH2O
34.7 dBA
25.0 dBA
Halbtransparent
1.9 V
2.9 V
506 U/min
226 U/min
54 U/min
378 U/min
1413 U/min
1319 U/min
440 U/min
41.1 CFM
+9.6 %
45.0 CFM
31.9 CFM
+12.6 %
28.4 CFM
30.7 CFM
+25.2 %
24.5 CFM
33.6 CFM
+27.1 %
26.4 CFM
69.8 m³/h
+9.6 %
76.5 m³/h
54.3 m³/h
+12.7 %
48.2 m³/h
52.1 m³/h
+25.2 %
41.6 m³/h
57.1 m³/h
+27.2 %
44.9 m³/h
+35.0 %
0.60 mmH2O
+42.0 %
+42.0 %
0.51 mmH2O
+19.6 %
+33.3 %
+40.0 %
+40.0 %
+20.0 %
32.6
-7.6 %
35.3
32.7
-11.4 %
36.9
33.2
-2.4 %
34
32.1
-7.8 %
34.8
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
