Sharkoon
Alphacool
Silent Storm PWM RGB Fan
Eiszyklon Aurora Lux Pro ARGB
168 g
200 g
400 U/min
600 U/min
1400 U/min
1500 U/min
2.6 W
58.3 CFM
121.9 m³/h
99.3 m³/h
1.47 mmH2O
1.60 mmH2O
34.7 dBA
38.0 dBA
3.3 V
1.9 V
2.9 V
506 U/min
316 U/min
54 U/min
393 U/min
1413 U/min
1499 U/min
440 U/min
41.1 CFM
+11.9 %
46.0 CFM
31.9 CFM
+29.0 %
24.8 CFM
30.7 CFM
+44.8 %
21.2 CFM
33.6 CFM
+39.2 %
24.1 CFM
69.8 m³/h
+11.9 %
78.1 m³/h
54.3 m³/h
+29.0 %
42.1 m³/h
52.1 m³/h
+44.7 %
36.0 m³/h
57.1 m³/h
+39.3 %
41.0 m³/h
+14.1 %
+77.5 %
0.40 mmH2O
+42.0 %
0.51 mmH2O
+27.5 %
0.40 mmH2O
+14.3 %
+75.0 %
+40.0 %
+25.0 %
32.6
-5.2 %
34.4
32.7
-4.1 %
34.1
33.2
-0.3 %
33.1
32.1
-1.2 %
32.5
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
