Sharkoon
Thermaltake
Silent Storm PWM RGB Fan
168 g
212 g
400 U/min
500 U/min
1400 U/min
2.6 W
58.4 CFM
121.9 m³/h
99.1 m³/h
1.47 mmH2O
2.41 mmH2O
34.7 dBA
22.3 dBA
Grau
1.9 V
506 U/min
391 U/min
54 U/min
413 U/min
1413 U/min
1950 U/min
440 U/min
41.1 CFM
+23.8 %
33.2 CFM
31.9 CFM
+26.8 %
25.2 CFM
30.7 CFM
+25.2 %
24.5 CFM
33.6 CFM
+61.3 %
20.8 CFM
69.8 m³/h
+23.8 %
56.4 m³/h
54.3 m³/h
+26.9 %
42.8 m³/h
52.1 m³/h
+25.3 %
41.6 m³/h
57.1 m³/h
+61.3 %
35.4 m³/h
+127.2 %
1.84 mmH2O
+14.1 %
+42.0 %
0.51 mmH2O
+27.5 %
0.40 mmH2O
+125.5 %
0.18 hPa
+13.5 %
+42.8 %
+27.5 %
32.6
-12.8 %
37.4
32.7
-10.4 %
36.5
33.2
-7.8 %
36
32.1
-11.3 %
36.2
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
