NZXT
Alphacool
F120 RGB
Eiszyklon Aurora Lux Pro ARGB
26 mm
205 g
200 g
500 U/min
600 U/min
1800 U/min
1500 U/min
0.4 W
1.8 W
50.2 CFM
58.3 CFM
85.2 m³/h
99.3 m³/h
2.70 mmH2O
1.60 mmH2O
27.5 dBA
38.0 dBA
4.7 V
3.3 V
4.4 V
2.9 V
827 U/min
316 U/min
703 U/min
393 U/min
1924 U/min
1499 U/min
447 U/min
24.2 CFM
+90.0 %
46.0 CFM
18.9 CFM
+30.7 %
24.8 CFM
13.0 CFM
+62.9 %
21.2 CFM
18.7 CFM
+29.0 %
24.1 CFM
41.1 m³/h
+90.0 %
78.1 m³/h
32.2 m³/h
+30.7 %
42.1 m³/h
22.1 m³/h
+62.9 %
36.0 m³/h
31.8 m³/h
+28.9 %
41.0 m³/h
0.91 mmH2O
+28.2 %
+102.5 %
0.40 mmH2O
+62.0 %
+102.5 %
0.40 mmH2O
0.09 hPa
+28.6 %
+100.0 %
+60.0 %
+100.0 %
24.8
-27.9 %
34.4
30.4
-10.9 %
34.1
32.4
-2.1 %
33.1
29.6
-8.9 %
32.5
  • 703
  • 903
  • 1103
  • 1303
  • 1503
  • 1703
  • 1903
