Thermalright
Alphacool
TL-B12 Extreme
Rise Aurora
25.6 mm
215 g
180 g
550 U/min
3150 U/min
2500 U/min
1.0 W
4.2 W
112.0 CFM
70.0 CFM
190.3 m³/h
118.9 m³/h
5.00 mmH2O
3.17 mmH2O
40.5 dBA
31.5 dBA
Rot, Weiß
1.8 V
3.0 V
1.4 V
2.9 V
293 U/min
862 U/min
163 U/min
874 U/min
339 U/min
181 U/min
2857 U/min
2775 U/min
554 U/min
1045 U/min
31.6 CFM
+9.0 %
29.0 CFM
23.7 CFM
+3.0 %
24.4 CFM
22.3 CFM
+5.3 %
23.5 CFM
21.1 CFM
+4.7 %
22.1 CFM
53.7 m³/h
+8.9 %
49.3 m³/h
40.3 m³/h
+3.0 %
41.5 m³/h
37.9 m³/h
+5.3 %
39.9 m³/h
35.8 m³/h
+4.7 %
37.5 m³/h
+16.0 %
+39.3 %
0.51 mmH2O
+98.6 %
0.41 mmH2O
+74.1 %
0.41 mmH2O
+16.7 %
+40.0 %
+100.0 %
+75.0 %
32.4
-22.1 %
41.6
31.1
-24.1 %
41
32.5
-16.9 %
39.1
30.5
-24.7 %
40.5
  • 163
  • 363
  • 563
  • 763
  • 963
  • 1163
  • 1363
  • 1563
  • 1763
  • 1963
  • 2163
  • 2363
  • 2563
  • 2763
