Thermalright
Cooler Master
TL-B12 Extreme
Sickleflow 140 ARGB
25.6 mm
215 g
195 g
550 U/min
650 U/min
3150 U/min
1400 U/min
1.0 W
4.2 W
112.0 CFM
67.0 CFM
190.3 m³/h
113.8 m³/h
5.00 mmH2O
2.25 mmH2O
40.5 dBA
27.0 dBA
Rot, Weiß
Halbtransparent
1.8 V
5.5 V
1.4 V
2.9 V
293 U/min
599 U/min
163 U/min
495 U/min
2857 U/min
1374 U/min
554 U/min
31.6 CFM
+43.4 %
45.3 CFM
23.7 CFM
+18.3 %
28.1 CFM
22.3 CFM
+16.9 %
26.1 CFM
21.1 CFM
+28.2 %
27.0 CFM
53.7 m³/h
+43.4 %
77.0 m³/h
40.3 m³/h
+18.4 %
47.7 m³/h
37.9 m³/h
+16.9 %
44.3 m³/h
35.8 m³/h
+28.2 %
45.9 m³/h
+42.0 %
+42.0 %
+62.0 %
+42.0 %
+40.0 %
+40.0 %
+60.0 %
+40.0 %
32.4
-8.7 %
35.5
31.1
-16.4 %
37.2
32.5
-0.9 %
32.8
30.5
-9.0 %
33.5
  • 163
  • 363
  • 563
  • 763
  • 963
  • 1163
  • 1363
  • 1563
  • 1763
  • 1963
  • 2163
  • 2363
  • 2563
  • 2763
