Thermalright
Noctua
TL-B12 Extreme
NF-A14 FLX
25.6 mm
215 g
210 g
550 U/min
900 U/min
3150 U/min
1200 U/min
1.0 W
4.2 W
112.0 CFM
68.0 CFM
190.3 m³/h
115.5 m³/h
5.00 mmH2O
1.51 mmH2O
40.5 dBA
19.2 dBA
Beige
Rot, Weiß
Braun
Braun
1.8 V
4.6 V
1.4 V
4.2 V
293 U/min
381 U/min
163 U/min
469 U/min
2857 U/min
1199 U/min
554 U/min
31.6 CFM
+69.3 %
53.5 CFM
23.7 CFM
+39.0 %
33.0 CFM
22.3 CFM
+42.0 %
31.7 CFM
21.1 CFM
+43.0 %
30.1 CFM
53.7 m³/h
+69.3 %
90.9 m³/h
40.3 m³/h
+39.0 %
56.0 m³/h
37.9 m³/h
+42.0 %
53.8 m³/h
35.8 m³/h
+43.0 %
51.2 m³/h
+28.2 %
0.91 mmH2O
+28.2 %
0.91 mmH2O
+62.0 %
+136.7 %
0.30 mmH2O
+28.6 %
0.09 hPa
+28.6 %
0.09 hPa
+60.0 %
+133.3 %
0.03 hPa
32.4
-5.3 %
34.2
31.1
-27.0 %
42.6
32.5
-20.3 %
40.8
30.5
-23.6 %
39.9
  • 163
  • 363
  • 563
  • 763
  • 963
  • 1163
  • 1363
  • 1563
  • 1763
  • 1963
  • 2163
  • 2363
  • 2563
  • 2763
