Sharkoon
Blacknoise
Silent Storm PWM RGB Fan
B12x-PS-BL PWM ARGB
135 g
120 g
400 U/min
1400 U/min
1500 U/min
2.2 W
58.1 CFM
93.6 m³/h
98.7 m³/h
1.80 mmH2O
20.4 dBA
21.2 dBA
3.6 V
3.3 V
585 U/min
386 U/min
561 U/min
570 U/min
1374 U/min
1491 U/min
513 U/min
34.0 CFM
+7.6 %
36.6 CFM
19.5 CFM
+20.8 %
23.5 CFM
24.4 CFM
+2.0 %
23.9 CFM
21.5 CFM
+5.7 %
22.8 CFM
57.8 m³/h
+7.6 %
62.2 m³/h
33.1 m³/h
+20.8 %
40.0 m³/h
41.5 m³/h
+4.3 %
39.8 m³/h
36.6 m³/h
+5.7 %
38.7 m³/h
+57.7 %
1.12 mmH2O
+16.4 %
0.61
0.61
+16.4 %
+57.1 %
0.11 hPa
+16.7 %
0.06
0.06
+16.7 %
31.7
-18.1 %
38.7
29.2
-23.0 %
37.9
27.5
-29.7 %
39.1
27.1
-26.8 %
37
  • 561
  • 761
  • 961
  • 1161
  • 1361
