Sharkoon
Cooler Master
Silent Storm PWM RGB Fan
Masterfan MF120 Halo
135 g
180 g
400 U/min
650 U/min
1400 U/min
1800 U/min
2.2 W
47.2 CFM
93.6 m³/h
20.4 dBA
30.0 dBA
Grau
Halbtransparent
3.6 V
3.3 V
585 U/min
166 U/min
561 U/min
590 U/min
1374 U/min
1792 U/min
513 U/min
34.0 CFM
+37.3 %
24.8 CFM
19.5 CFM
+2.1 %
19.9 CFM
24.4 CFM
+20.7 %
20.2 CFM
21.5 CFM
+24.9 %
17.2 CFM
57.8 m³/h
+37.3 %
42.1 m³/h
33.1 m³/h
+2.1 %
33.8 m³/h
41.5 m³/h
+32.2 %
31.4 m³/h
36.6 m³/h
+24.9 %
29.3 m³/h
+77.5 %
0.40 mmH2O
+32.8 %
+52.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+75.0 %
+33.3 %
+50.0 %
+50.0 %
31.7
-16.1 %
37.8
29.2
-19.8 %
36.4
27.5
-24.7 %
36.5
27.1
-23.9 %
35.6
  • 561
  • 761
  • 961
  • 1161
  • 1361
