Sharkoon
MSI
Silent Storm PWM RGB Fan
MEG Silent Gale P12
27.5 mm
135 g
209 g
400 U/min
1400 U/min
0.7 W
2.2 W
1.4 W
56.2 CFM
93.6 m³/h
95.5 m³/h
2.21 mmH2O
20.4 dBA
22.7 dBA
3.6 V
5.5 V
4.3 V
585 U/min
906 U/min
561 U/min
742 U/min
194 U/min
186 U/min
1374 U/min
1980 U/min
513 U/min
512 U/min
34.0 CFM
+9.3 %
31.1 CFM
19.5 CFM
+10.6 %
21.5 CFM
24.4 CFM
+10.6 %
22.1 CFM
21.5 CFM
+9.5 %
19.7 CFM
57.8 m³/h
+9.3 %
52.9 m³/h
33.1 m³/h
+10.6 %
36.6 m³/h
41.5 m³/h
+10.7 %
37.5 m³/h
36.6 m³/h
+9.6 %
33.4 m³/h
+28.2 %
0.91 mmH2O
+32.8 %
+32.8 %
+32.8 %
+28.6 %
0.09 hPa
+33.3 %
+33.3 %
+33.3 %
31.7
-1.6 %
31.2
29.2
-16.1 %
34.8
27.5
-20.5 %
34.6
27.1
-18.1 %
33.1
  • 561
  • 761
  • 961
  • 1161
  • 1361
