Sharkoon
Blacknoise
Silent Storm PWM RGB Fan
NB-eLoop X PWM B12xP ARGB
135 g
120 g
400 U/min
400 U/min
1400 U/min
2.2 W
77.9 CFM
93.6 m³/h
132.4 m³/h
3.02 mmH2O
20.4 dBA
28.4 dBA
Grau
3.6 V
3.4 V
585 U/min
294 U/min
561 U/min
138 U/min
1374 U/min
2002 U/min
513 U/min
34.0 CFM
+19.2 %
40.5 CFM
19.5 CFM
+27.8 %
24.9 CFM
24.4 CFM
+6.1 %
23.0 CFM
21.5 CFM
+2.5 %
21.0 CFM
57.8 m³/h
+19.2 %
68.9 m³/h
33.1 m³/h
+27.8 %
42.3 m³/h
41.5 m³/h
+6.1 %
39.1 m³/h
36.6 m³/h
+2.5 %
35.7 m³/h
+101.4 %
1.43 mmH2O
+32.8 %
0.61
0.61
+22.0 %
+100.0 %
0.14 hPa
+33.3 %
0.06
0.06
+20.0 %
31.7
-7.8 %
34.4
29.2
-20.0 %
36.5
27.5
-23.4 %
35.9
27.1
-24.9 %
36.1
  • 561
  • 761
  • 961
  • 1161
  • 1361
