Sharkoon
Alphacool
Silent Storm PWM RGB Fan
Rise Aurora
135 g
180 g
400 U/min
1400 U/min
2500 U/min
2.2 W
70.0 CFM
93.6 m³/h
118.9 m³/h
3.17 mmH2O
20.4 dBA
31.5 dBA
3.6 V
3.0 V
2.9 V
585 U/min
862 U/min
561 U/min
874 U/min
339 U/min
181 U/min
1374 U/min
2775 U/min
513 U/min
1045 U/min
34.0 CFM
+17.2 %
29.0 CFM
19.5 CFM
+25.4 %
24.4 CFM
24.4 CFM
+4.0 %
23.5 CFM
21.5 CFM
+2.5 %
22.1 CFM
57.8 m³/h
+17.2 %
49.3 m³/h
33.1 m³/h
+25.4 %
41.5 m³/h
41.5 m³/h
+4.0 %
39.9 m³/h
36.6 m³/h
+2.5 %
37.5 m³/h
+16.0 %
+19.6 %
0.51 mmH2O
+49.5 %
0.41 mmH2O
+49.5 %
0.41 mmH2O
+16.7 %
+20.0 %
+50.0 %
+50.0 %
31.7
-23.8 %
41.6
29.2
-28.8 %
41
27.5
-29.7 %
39.1
27.1
-33.1 %
40.5
  • 561
  • 761
  • 961
  • 1161
  • 1361
