Sharkoon
Silent Storm PWM RGB Fan
Silent Wings 3
135 g
137 g
400 U/min
150 U/min
1400 U/min
1450 U/min
2.2 W
50.5 CFM
93.6 m³/h
85.8 m³/h
1.79 mmH2O
20.4 dBA
16.4 dBA
3.6 V
4.1 V
3.9 V
585 U/min
561 U/min
206 U/min
244 U/min
1374 U/min
1411 U/min
513 U/min
34.0 CFM
+50.9 %
22.5 CFM
19.5 CFM
+2.1 %
19.9 CFM
24.4 CFM
+41.6 %
17.2 CFM
21.5 CFM
+28.4 %
16.8 CFM
57.8 m³/h
+50.9 %
38.3 m³/h
33.1 m³/h
+2.1 %
33.8 m³/h
41.5 m³/h
+41.6 %
29.3 m³/h
36.6 m³/h
+28.4 %
28.5 m³/h
+42.3 %
1.01 mmH2O
+16.4 %
+16.4 %
+22.0 %
+41.5 %
+16.0 %
+16.0 %
+22.4 %
31.7
-13.9 %
36.8
29.2
-30.1 %
41.8
27.5
-32.1 %
40.5
27.1
-33.3 %
40.6
  • 561
  • 761
  • 961
  • 1161
  • 1361
