Sharkoon
Noctua
Silent Storm PWM RGB Fan
NF-A14 FLX
135 g
210 g
400 U/min
900 U/min
1400 U/min
1200 U/min
2.2 W
68.0 CFM
93.6 m³/h
115.5 m³/h
1.51 mmH2O
20.4 dBA
19.2 dBA
Beige
Braun
Braun
3.6 V
4.6 V
4.2 V
585 U/min
381 U/min
561 U/min
469 U/min
1374 U/min
1199 U/min
513 U/min
34.0 CFM
+57.3 %
53.5 CFM
19.5 CFM
+69.2 %
33.0 CFM
24.4 CFM
+29.7 %
31.7 CFM
21.5 CFM
+39.9 %
30.1 CFM
57.8 m³/h
+57.3 %
90.9 m³/h
33.1 m³/h
+69.2 %
56.0 m³/h
41.5 m³/h
+29.6 %
53.8 m³/h
36.6 m³/h
+39.9 %
51.2 m³/h
+28.2 %
0.91 mmH2O
+49.2 %
0.91 mmH2O
+22.0 %
+103.3 %
0.30 mmH2O
+28.6 %
0.09 hPa
+50.0 %
0.09 hPa
+20.0 %
+100.0 %
0.03 hPa
31.7
-7.3 %
34.2
29.2
-31.5 %
42.6
27.5
-32.6 %
40.8
27.1
-32.1 %
39.9
  • 561
  • 761
  • 961
  • 1161
  • 1361
