Corsair
Cooler Master
ML 120 RGB Elite
Masterfan MF120 Halo
186 g
180 g
450 U/min
650 U/min
1800 U/min
1.6 W
58.1 CFM
47.2 CFM
98.7 m³/h
2.90 mmH2O
30.4 dBA
30.0 dBA
Grau
Halbtransparent
3.0 V
3.3 V
510 U/min
166 U/min
450 U/min
590 U/min
169 U/min
84 U/min
1993 U/min
1792 U/min
35.2 CFM
+42.3 %
24.8 CFM
24.2 CFM
+21.6 %
19.9 CFM
23.7 CFM
+17.1 %
20.2 CFM
21.3 CFM
+23.5 %
17.2 CFM
59.9 m³/h
+42.3 %
42.1 m³/h
41.1 m³/h
+21.6 %
33.8 m³/h
40.3 m³/h
+28.3 %
31.4 m³/h
36.2 m³/h
+23.5 %
29.3 m³/h
+77.5 %
0.40 mmH2O
+32.8 %
+52.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+75.0 %
+33.3 %
+50.0 %
+75.0 %
28.5
-24.6 %
37.8
29.5
-19.0 %
36.4
28.5
-21.9 %
36.5
27.8
-21.9 %
35.6
  • 169
  • 369
  • 569
  • 769
  • 969
  • 1169
  • 1369
  • 1569
  • 1769
  • 1969
