Corsair
MSI
ML 120 RGB Elite
MEG Silent Gale P12
27.5 mm
186 g
209 g
450 U/min
0.7 W
1.6 W
1.4 W
58.1 CFM
56.2 CFM
98.7 m³/h
95.5 m³/h
2.90 mmH2O
2.21 mmH2O
30.4 dBA
22.7 dBA
3.0 V
5.5 V
4.3 V
510 U/min
906 U/min
450 U/min
742 U/min
169 U/min
194 U/min
84 U/min
186 U/min
1993 U/min
1980 U/min
512 U/min
35.2 CFM
+13.2 %
31.1 CFM
24.2 CFM
+12.3 %
21.5 CFM
23.7 CFM
+7.4 %
22.1 CFM
21.3 CFM
+8.2 %
19.7 CFM
59.9 m³/h
+13.2 %
52.9 m³/h
41.1 m³/h
+12.3 %
36.6 m³/h
40.3 m³/h
+7.5 %
37.5 m³/h
36.2 m³/h
+8.4 %
33.4 m³/h
+28.2 %
0.91 mmH2O
+32.8 %
+32.8 %
+14.1 %
+28.6 %
0.09 hPa
+33.3 %
+33.3 %
+14.3 %
28.5
-8.7 %
31.2
29.5
-15.2 %
34.8
28.5
-17.6 %
34.6
27.8
-16.0 %
33.1
  • 169
  • 369
  • 569
  • 769
  • 969
  • 1169
  • 1369
  • 1569
  • 1769
  • 1969
