Corsair
Lian Li
ML 120 RGB Elite
UNI FAN SL120 ARGB
186 g
232 g
450 U/min
800 U/min
1900 U/min
1.6 W
58.1 CFM
58.5 CFM
98.7 m³/h
99.5 m³/h
2.90 mmH2O
1.67 mmH2O
30.4 dBA
31.0 dBA
Silber
3.0 V
2.4 V
510 U/min
412 U/min
450 U/min
98 U/min
169 U/min
84 U/min
1993 U/min
1828 U/min
35.2 CFM
+51.7 %
23.2 CFM
24.2 CFM
+36.6 %
17.7 CFM
23.7 CFM
+49.8 %
15.8 CFM
21.3 CFM
+39.2 %
15.3 CFM
59.9 m³/h
+51.6 %
39.5 m³/h
41.1 m³/h
+36.5 %
30.1 m³/h
40.3 m³/h
+49.8 %
26.9 m³/h
36.2 m³/h
+39.2 %
26.0 m³/h
+77.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+75.0 %
+50.0 %
+50.0 %
+75.0 %
28.5
-26.5 %
38.8
29.5
-19.6 %
36.7
28.5
-21.1 %
36.1
27.8
-19.7 %
34.6
  • 169
  • 369
  • 569
  • 769
  • 969
  • 1169
  • 1369
  • 1569
  • 1769
  • 1969
