Corsair
Corsair
ML 120 RGB Elite
LL140 RGB
186 g
210 g
450 U/min
600 U/min
1300 U/min
1.6 W
58.1 CFM
51.5 CFM
98.7 m³/h
87.5 m³/h
2.90 mmH2O
1.52 mmH2O
30.4 dBA
25.0 dBA
Halbtransparent
3.0 V
2.9 V
510 U/min
226 U/min
450 U/min
378 U/min
169 U/min
84 U/min
1993 U/min
1319 U/min
35.2 CFM
+27.7 %
45.0 CFM
24.2 CFM
+17.3 %
28.4 CFM
23.7 CFM
+3.3 %
24.5 CFM
21.3 CFM
+24.1 %
26.4 CFM
59.9 m³/h
+27.7 %
76.5 m³/h
41.1 m³/h
+17.3 %
48.2 m³/h
40.3 m³/h
+3.2 %
41.6 m³/h
36.2 m³/h
+24.0 %
44.9 m³/h
+18.3 %
0.60 mmH2O
+22.0 %
+22.0 %
+16.4 %
+16.7 %
+20.0 %
+20.0 %
+16.7 %
28.5
-19.3 %
35.3
29.5
-20.1 %
36.9
28.5
-16.2 %
34
27.8
-20.1 %
34.8
  • 169
  • 369
  • 569
  • 769
  • 969
  • 1169
  • 1369
  • 1569
  • 1769
  • 1969
