Corsair
Cooler Master
ML 120 RGB Elite
Sickleflow 140 ARGB
186 g
195 g
450 U/min
650 U/min
1400 U/min
1.6 W
58.1 CFM
67.0 CFM
98.7 m³/h
113.8 m³/h
2.90 mmH2O
2.25 mmH2O
30.4 dBA
27.0 dBA
Halbtransparent
3.0 V
5.5 V
2.9 V
510 U/min
599 U/min
450 U/min
495 U/min
169 U/min
84 U/min
1993 U/min
1374 U/min
35.2 CFM
+28.6 %
45.3 CFM
24.2 CFM
+16.0 %
28.1 CFM
23.7 CFM
+10.0 %
26.1 CFM
21.3 CFM
+26.8 %
27.0 CFM
59.9 m³/h
+28.5 %
77.0 m³/h
41.1 m³/h
+16.1 %
47.7 m³/h
40.3 m³/h
+9.9 %
44.3 m³/h
36.2 m³/h
+26.8 %
45.9 m³/h
+42.0 %
+22.0 %
+22.0 %
+42.0 %
+40.0 %
+20.0 %
+20.0 %
+40.0 %
28.5
-19.7 %
35.5
29.5
-20.7 %
37.2
28.5
-13.1 %
32.8
27.8
-17.0 %
33.5
  • 169
  • 369
  • 569
  • 769
  • 969
  • 1169
  • 1369
  • 1569
  • 1769
  • 1969
