Fractal
Cooler Master
Prisma AL-12PWM
Masterfan MF120 Halo
167 g
180 g
500 U/min
650 U/min
1800 U/min
1.9 W
85.7 CFM
47.2 CFM
145.7 m³/h
2.80 mmH2O
32.0 dBA
30.0 dBA
Grau
Halbtransparent
4.5 V
3.3 V
3.8 V
443 U/min
166 U/min
269 U/min
590 U/min
2001 U/min
1792 U/min
550 U/min
31.6 CFM
+27.6 %
24.8 CFM
20.7 CFM
+4.1 %
19.9 CFM
20.8 CFM
+2.9 %
20.2 CFM
19.8 CFM
+14.7 %
17.2 CFM
53.7 m³/h
+27.6 %
42.1 m³/h
35.2 m³/h
+4.1 %
33.8 m³/h
35.4 m³/h
+12.7 %
31.4 m³/h
33.6 m³/h
+14.7 %
29.3 m³/h
+102.5 %
0.40 mmH2O
+14.1 %
+77.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+100.0 %
+14.3 %
+75.0 %
+50.0 %
35.5
-6.1 %
37.8
33.6
-7.7 %
36.4
31.9
-12.6 %
36.5
28.6
-19.7 %
35.6
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
