Fractal
Arctic
Prisma AL-12PWM
P14 PWM
167 g
194 g
500 U/min
200 U/min
1700 U/min
1.9 W
85.7 CFM
72.8 CFM
145.7 m³/h
123.8 m³/h
2.80 mmH2O
2.40 mmH2O
32.0 dBA
4.5 V
3.8 V
3.8 V
443 U/min
395 U/min
269 U/min
481 U/min
2001 U/min
1733 U/min
550 U/min
31.6 CFM
+44.5 %
45.7 CFM
20.7 CFM
+30.7 %
27.1 CFM
20.8 CFM
+23.7 %
25.8 CFM
19.8 CFM
+36.6 %
27.0 CFM
53.7 m³/h
+44.5 %
77.6 m³/h
35.2 m³/h
+30.7 %
46.0 m³/h
35.4 m³/h
+23.7 %
43.8 m³/h
33.6 m³/h
+36.6 %
45.9 m³/h
+35.0 %
0.60 mmH2O
+77.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+33.3 %
+75.0 %
+75.0 %
+50.0 %
35.5
-13.5 %
30.7
33.6
-9.5 %
30.4
31.9
-6.0 %
30
28.6
-6.5 %
30.6
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
