Fractal
Cooler Master
Prisma AL-12PWM
Sickleflow 140 ARGB
167 g
195 g
500 U/min
650 U/min
1400 U/min
1.9 W
85.7 CFM
67.0 CFM
145.7 m³/h
113.8 m³/h
2.80 mmH2O
2.25 mmH2O
32.0 dBA
27.0 dBA
Halbtransparent
4.5 V
5.5 V
3.8 V
2.9 V
443 U/min
599 U/min
269 U/min
495 U/min
2001 U/min
1374 U/min
550 U/min
31.6 CFM
+43.4 %
45.3 CFM
20.7 CFM
+35.5 %
28.1 CFM
20.8 CFM
+25.2 %
26.1 CFM
19.8 CFM
+36.6 %
27.0 CFM
53.7 m³/h
+43.4 %
77.0 m³/h
35.2 m³/h
+35.5 %
47.7 m³/h
35.4 m³/h
+25.1 %
44.3 m³/h
33.6 m³/h
+36.6 %
45.9 m³/h
+62.0 %
+42.0 %
+42.0 %
+22.0 %
+60.0 %
+40.0 %
+40.0 %
+20.0 %
35.5
35.5
33.6
-9.7 %
37.2
31.9
-2.7 %
32.8
28.6
-14.6 %
33.5
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
