Fractal
Noctua
Prisma AL-12PWM
NF-A14 FLX
167 g
210 g
500 U/min
900 U/min
1200 U/min
1.9 W
85.7 CFM
68.0 CFM
145.7 m³/h
115.5 m³/h
2.80 mmH2O
1.51 mmH2O
32.0 dBA
19.2 dBA
Beige
Braun
Braun
4.5 V
4.6 V
3.8 V
4.2 V
443 U/min
381 U/min
269 U/min
469 U/min
2001 U/min
1199 U/min
550 U/min
31.6 CFM
+69.3 %
53.5 CFM
20.7 CFM
+59.2 %
33.0 CFM
20.8 CFM
+52.0 %
31.7 CFM
19.8 CFM
+52.4 %
30.1 CFM
53.7 m³/h
+69.3 %
90.9 m³/h
35.2 m³/h
+59.1 %
56.0 m³/h
35.4 m³/h
+52.0 %
53.8 m³/h
33.6 m³/h
+52.4 %
51.2 m³/h
+12.3 %
0.91 mmH2O
+28.2 %
0.91 mmH2O
+42.0 %
+103.3 %
0.30 mmH2O
+12.5 %
0.09 hPa
+28.6 %
0.09 hPa
+40.0 %
+100.0 %
0.03 hPa
35.5
-3.7 %
34.2
33.6
-21.1 %
42.6
31.9
-21.8 %
40.8
28.6
-28.3 %
39.9
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
