Corsair
MSI
QL120 RGB
MEG Silent Gale P12
27.5 mm
163 g
209 g
500 U/min
1500 U/min
0.7 W
1.4 W
41.8 CFM
56.2 CFM
95.5 m³/h
1.55 mmH2O
2.21 mmH2O
26.0 dBA
22.7 dBA
Silber
Halbtransparent
3.0 V
5.5 V
4.3 V
245 U/min
906 U/min
472 U/min
742 U/min
194 U/min
186 U/min
1600 U/min
1980 U/min
512 U/min
27.8 CFM
+12.1 %
31.1 CFM
20.6 CFM
+4.6 %
21.5 CFM
19.2 CFM
+15.1 %
22.1 CFM
17.2 CFM
+14.2 %
19.7 CFM
47.2 m³/h
+12.1 %
52.9 m³/h
35.0 m³/h
+4.6 %
36.6 m³/h
32.6 m³/h
+15.0 %
37.5 m³/h
29.3 m³/h
+14.0 %
33.4 m³/h
1.01 mmH2O
+11.0 %
0.91 mmH2O
+62.0 %
+62.0 %
0.40 mmH2O
+102.5 %
+11.1 %
0.09 hPa
+60.0 %
+60.0 %
+100.0 %
38.4
-18.8 %
31.2
38.3
-9.1 %
34.8
35.9
-3.6 %
34.6
35.8
-7.5 %
33.1
