Corsair
Blacknoise
QL120 RGB
NB-eLoop X PWM B12xP ARGB
163 g
120 g
500 U/min
400 U/min
1500 U/min
41.8 CFM
77.9 CFM
132.4 m³/h
1.55 mmH2O
3.02 mmH2O
26.0 dBA
28.4 dBA
Silber
Grau
Halbtransparent
3.0 V
3.4 V
245 U/min
294 U/min
472 U/min
138 U/min
1600 U/min
2002 U/min
27.8 CFM
+46.0 %
40.5 CFM
20.6 CFM
+20.8 %
24.9 CFM
19.2 CFM
+20.0 %
23.0 CFM
17.2 CFM
+21.9 %
21.0 CFM
47.2 m³/h
+46.0 %
68.9 m³/h
35.0 m³/h
+20.9 %
42.3 m³/h
32.6 m³/h
+19.9 %
39.1 m³/h
29.3 m³/h
+21.8 %
35.7 m³/h
1.01 mmH2O
+41.6 %
1.43 mmH2O
+62.0 %
+22.0 %
0.40 mmH2O
+25.0 %
+40.0 %
0.14 hPa
+60.0 %
+20.0 %
+25.0 %
38.4
-10.4 %
34.4
38.3
-4.7 %
36.5
35.9
35.9
35.8
-0.8 %
36.1
