Sharkoon
Light Wings 140 PWM HS
Silent Storm PWM RGB Fan
266 g
168 g
250 U/min
400 U/min
2200 U/min
1400 U/min
1.9 W
4.7 W
2.6 W
71.7 CFM
121.8 m³/h
121.9 m³/h
2.30 mmH2O
1.47 mmH2O
31.0 dBA
34.7 dBA
3.0 V
1.9 V
565 U/min
506 U/min
556 U/min
54 U/min
2264 U/min
1413 U/min
241 U/min
440 U/min
40.1 CFM
+2.3 %
41.1 CFM
24.4 CFM
+30.8 %
31.9 CFM
22.5 CFM
+36.4 %
30.7 CFM
24.1 CFM
+39.2 %
33.6 CFM
68.2 m³/h
+2.3 %
69.8 m³/h
41.5 m³/h
+30.8 %
54.3 m³/h
38.2 m³/h
+36.4 %
52.1 m³/h
41.0 m³/h
+39.3 %
57.1 m³/h
1.83 mmH2O
+125.9 %
+16.4 %
+16.4 %
+19.6 %
0.51 mmH2O
0.18 hPa
+125.0 %
+16.7 %
+16.7 %
+20.0 %
25.5
-21.8 %
32.6
26.7
-18.3 %
32.7
25.7
-22.6 %
33.2
25.5
-20.6 %
32.1
  • 556
  • 756
  • 956
  • 1156
  • 1356
  • 1556
  • 1756
  • 1956
  • 2156
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
