NZXT
Light Wings 140 PWM HS
F120 RGB
26 mm
266 g
205 g
250 U/min
500 U/min
2200 U/min
1800 U/min
1.9 W
0.4 W
4.7 W
1.8 W
71.7 CFM
50.2 CFM
121.8 m³/h
85.2 m³/h
2.30 mmH2O
2.70 mmH2O
31.0 dBA
27.5 dBA
3.0 V
4.7 V
4.4 V
565 U/min
827 U/min
556 U/min
703 U/min
2264 U/min
1924 U/min
241 U/min
447 U/min
40.1 CFM
+65.9 %
24.2 CFM
24.4 CFM
+28.9 %
18.9 CFM
22.5 CFM
+72.9 %
13.0 CFM
24.1 CFM
+29.0 %
18.7 CFM
68.2 m³/h
+65.9 %
41.1 m³/h
41.5 m³/h
+28.9 %
32.2 m³/h
38.2 m³/h
+72.9 %
22.1 m³/h
41.0 m³/h
+28.9 %
31.8 m³/h
1.83 mmH2O
+101.1 %
0.91 mmH2O
+32.8 %
+32.8 %
+32.8 %
0.18 hPa
+100.0 %
0.09 hPa
+33.3 %
+33.3 %
+33.3 %
25.5
-2.7 %
24.8
26.7
-12.2 %
30.4
25.7
-20.7 %
32.4
25.5
-13.9 %
29.6
  • 556
  • 756
  • 956
  • 1156
  • 1356
  • 1556
  • 1756
  • 1956
  • 2156
  • 703
  • 903
  • 1103
  • 1303
  • 1503
  • 1703
  • 1903
