Lian Li
Light Wings 140 PWM HS
UNI FAN SL120 ARGB
266 g
232 g
250 U/min
800 U/min
2200 U/min
1900 U/min
1.9 W
4.7 W
71.7 CFM
58.5 CFM
121.8 m³/h
99.5 m³/h
2.30 mmH2O
1.67 mmH2O
31.0 dBA
31.0 dBA
Silber
3.0 V
2.4 V
565 U/min
412 U/min
556 U/min
98 U/min
2264 U/min
1828 U/min
241 U/min
40.1 CFM
+72.7 %
23.2 CFM
24.4 CFM
+37.9 %
17.7 CFM
22.5 CFM
+42.0 %
15.8 CFM
24.1 CFM
+57.7 %
15.3 CFM
68.2 m³/h
+72.7 %
39.5 m³/h
41.5 m³/h
+37.9 %
30.1 m³/h
38.2 m³/h
+42.0 %
26.9 m³/h
41.0 m³/h
+57.7 %
26.0 m³/h
1.83 mmH2O
+357.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
0.18 hPa
+350.0 %
+50.0 %
+50.0 %
+50.0 %
25.5
-34.3 %
38.8
26.7
-27.2 %
36.7
25.7
-28.8 %
36.1
25.5
-26.3 %
34.6
  • 556
  • 756
  • 956
  • 1156
  • 1356
  • 1556
  • 1756
  • 1956
  • 2156
