Blacknoise
Light Wings 140 PWM HS
B14x-P-BL PWM ARGB
266 g
202 g
250 U/min
2200 U/min
1500 U/min
1.9 W
0.5 W
4.7 W
2.9 W
71.7 CFM
110.0 CFM
121.8 m³/h
186.0 m³/h
2.30 mmH2O
2.30 mmH2O
31.0 dBA
29.6 dBA
3.0 V
4.3 V
565 U/min
335 U/min
556 U/min
154 U/min
2264 U/min
1487 U/min
241 U/min
40.1 CFM
+50.1 %
60.3 CFM
24.4 CFM
+36.2 %
33.2 CFM
22.5 CFM
+43.7 %
32.3 CFM
24.1 CFM
+37.8 %
33.2 CFM
68.2 m³/h
+50.1 %
102.4 m³/h
41.5 m³/h
+36.1 %
56.5 m³/h
38.2 m³/h
+43.7 %
54.9 m³/h
41.0 m³/h
+37.8 %
56.5 m³/h
1.83 mmH2O
+38.6 %
1.32 mmH2O
+116.4 %
1.32 mmH2O
+65.6 %
1.01 mmH2O
+100.0 %
1.22 mmH2O
0.18 hPa
+38.5 %
0.13 hPa
+116.7 %
0.13 hPa
+66.7 %
+100.0 %
0.12 hPa
25.5
-24.3 %
33.7
26.7
-28.6 %
37.4
25.7
-29.8 %
36.6
25.5
-29.2 %
36
  • 556
  • 756
  • 956
  • 1156
  • 1356
  • 1556
  • 1756
  • 1956
  • 2156
