Blacknoise
Light Wings PWM HS
B12x-PS-BL PWM ARGB
210 g
120 g
300 U/min
2500 U/min
1500 U/min
1.4 W
5.4 W
52.3 CFM
58.1 CFM
88.9 m³/h
98.7 m³/h
2.60 mmH2O
1.80 mmH2O
31.0 dBA
21.2 dBA
3.3 V
608 U/min
386 U/min
565 U/min
570 U/min
2489 U/min
1491 U/min
248 U/min
32.5 CFM
+12.5 %
36.6 CFM
18.5 CFM
+27.4 %
23.5 CFM
18.9 CFM
+26.4 %
23.9 CFM
17.7 CFM
+28.6 %
22.8 CFM
55.3 m³/h
+12.5 %
62.2 m³/h
31.4 m³/h
+27.4 %
40.0 m³/h
32.2 m³/h
+23.6 %
39.8 m³/h
30.1 m³/h
+28.6 %
38.7 m³/h
+57.7 %
1.12 mmH2O
+42.0 %
0.40 mmH2O
+52.5 %
+42.0 %
+57.1 %
0.11 hPa
+40.0 %
+50.0 %
+40.0 %
33.7
-12.9 %
38.7
31.6
-16.6 %
37.9
32
-18.2 %
39.1
30.7
-17.0 %
37
  • 565
  • 765
  • 965
  • 1165
  • 1365
  • 1565
  • 1765
  • 1965
  • 2165
  • 2365
