Cooler Master
Light Wings PWM HS
Masterfan MF120 Halo
210 g
180 g
300 U/min
650 U/min
2500 U/min
1800 U/min
1.4 W
5.4 W
52.3 CFM
47.2 CFM
88.9 m³/h
2.60 mmH2O
31.0 dBA
30.0 dBA
Grau
Halbtransparent
3.3 V
608 U/min
166 U/min
565 U/min
590 U/min
2489 U/min
1792 U/min
248 U/min
32.5 CFM
+31.4 %
24.8 CFM
18.5 CFM
+7.6 %
19.9 CFM
18.9 CFM
+6.8 %
20.2 CFM
17.7 CFM
+2.7 %
17.2 CFM
55.3 m³/h
+31.4 %
42.1 m³/h
31.4 m³/h
+7.6 %
33.8 m³/h
32.2 m³/h
+2.5 %
31.4 m³/h
30.1 m³/h
+2.7 %
29.3 m³/h
+77.5 %
0.40 mmH2O
+62.0 %
0.4
0.4
+25.0 %
0.40 mmH2O
+75.0 %
+60.0 %
0.04
0.04
+25.0 %
33.7
-10.8 %
37.8
31.6
-13.2 %
36.4
32
-12.3 %
36.5
30.7
-13.8 %
35.6
  • 565
  • 765
  • 965
  • 1165
  • 1365
  • 1565
  • 1765
  • 1965
  • 2165
  • 2365
