Blacknoise
Light Wings PWM HS
NB-eLoop X PWM B12xP ARGB
210 g
120 g
300 U/min
400 U/min
2500 U/min
1.4 W
5.4 W
52.3 CFM
77.9 CFM
88.9 m³/h
132.4 m³/h
2.60 mmH2O
3.02 mmH2O
31.0 dBA
28.4 dBA
Grau
3.4 V
608 U/min
294 U/min
565 U/min
138 U/min
2489 U/min
2002 U/min
248 U/min
32.5 CFM
+24.6 %
40.5 CFM
18.5 CFM
+34.7 %
24.9 CFM
18.9 CFM
+21.4 %
23.0 CFM
17.7 CFM
+18.6 %
21.0 CFM
55.3 m³/h
+24.6 %
68.9 m³/h
31.4 m³/h
+34.7 %
42.3 m³/h
32.2 m³/h
+21.4 %
39.1 m³/h
30.1 m³/h
+18.6 %
35.7 m³/h
+101.4 %
1.43 mmH2O
+62.0 %
0.40 mmH2O
+52.5 %
0.5
0.5
+100.0 %
0.14 hPa
+60.0 %
+50.0 %
0.05
0.05
33.7
-2.0 %
34.4
31.6
-13.4 %
36.5
32
-10.9 %
35.9
30.7
-15.0 %
36.1
  • 565
  • 765
  • 965
  • 1165
  • 1365
  • 1565
  • 1765
  • 1965
  • 2165
  • 2365
