Light Wings PWM HS
Silent Wings 3
210 g
137 g
300 U/min
150 U/min
2500 U/min
1450 U/min
1.4 W
5.4 W
52.3 CFM
50.5 CFM
88.9 m³/h
85.8 m³/h
2.60 mmH2O
1.79 mmH2O
31.0 dBA
16.4 dBA
4.1 V
3.9 V
608 U/min
565 U/min
206 U/min
244 U/min
2489 U/min
1411 U/min
248 U/min
32.5 CFM
+44.4 %
22.5 CFM
18.5 CFM
+7.6 %
19.9 CFM
18.9 CFM
+9.9 %
17.2 CFM
17.7 CFM
+5.6 %
16.8 CFM
55.3 m³/h
+44.4 %
38.3 m³/h
31.4 m³/h
+7.6 %
33.8 m³/h
32.2 m³/h
+9.9 %
29.3 m³/h
30.1 m³/h
+5.6 %
28.5 m³/h
+42.3 %
1.01 mmH2O
+42.0 %
0.40 mmH2O
+77.5 %
0.5
0.5
+41.5 %
+39.3 %
+74.1 %
+2.0 %
33.7
-8.4 %
36.8
31.6
-24.4 %
41.8
32
-21.0 %
40.5
30.7
-24.4 %
40.6
  • 565
  • 765
  • 965
  • 1165
  • 1365
  • 1565
  • 1765
  • 1965
  • 2165
  • 2365
